Linkliste:
Versionen der V10.2 2020.36
V10.2 2020.36.16 KW41/2020
V10.2 2020.36.11 KW38/2020
V10.2 2020.36.10 KW37/2020
- Ampel- und Stopschilderkennung in D
V10.2 2020.36.4.5 KW39/2020
V10.2 2020.36.4 KW38/2020
V10.2 2020.36.3.1 KW37/2020
V10.2 2020.36.3 KW36/2020
V10.2 2020.36 KW34/2020
- Kameraerkennung von Geschwindigkeitsbeschränkungen
- Hinweistöne bei Erkennung von grünen Ampeln
- Verbesserung der Einstellung der Tempomatgeschwindigkeit
- Warnung vor roten Ampeln und Stopschilder bei Autopilot
Release-Notes der 2020.36:
Release Notes
Autosteer Stop Sign and Stop Light Warning
Your car may warn you in some cases if it detects that you are about to run a stop sign or stop light while Autosteer is in use. This is not a substitute for an attentive driver and will not stop the car.
Green Traffic Light Chime
A chime will play when the traffic light you are waiting for turns green. If you are waiting behind another car, the chime will play once the car advances unless Traffic-Aware Cruise Control or Autosteer is active. When Traffic Light and Stop Sign Control is activated, a chime will play when you can confirm to proceed through a green traffic light. To enable, tap Controls > Autopilot > Green Traffic Light Chime.
Note: This chime is only designed as a notification. It is the drvier’s responsibility to observe their environment and make decisions accordingly.
Cruise Set Speed Improvements
Quickly adjust the Traffic-Aware Cruise Control or Autosteer set speed to the current speed by simply tapping the cluster speedometer. You can still tap the speed limit sign to adjust the set speed to the speed limit.
Speed Assist Improvements
Speed Assist now leverages your car’s cameras to detect speed limit signs to improve the accuracy of speed limit data on local roads. Detected speed limit signs will be displayed in the driving visualization and used to set the associated Speed Limit Warning.
As usual to adjust Speed Assist settings, tap Controls > Autopilot > Speed Limit.
Changelog von 2020.36.10 (lt. dieser Quelle)
