European Type Approval Model S and Model X Refresh issued!
Model X Plaid and Model S Long Range certified
Model S Long Range
- WLTP Combined Range 649km
- WLTP Consumption 175Wh/km
- Test Mass 2257Kg
- Load Capacity 439Kg
Model X Plaid
- WLTP Combined Range 528km
- WLTP Consumption 214Wh/km
- Test Mass 2661Kg
- Load Capacity S5=431Kg / S6=506Kg / S7=581Kg
Battery Pack
- Panasonic 100kWh
- Nominal Voltage 408V
- Voltage Range 280-460V
Drive Unit - Long Range
- Front DU → 3D8 → 252kW / 421Nm / 325V / Ratio 7.56
- Rear DU → 3D1 → 252kW / 421Nm / 325V / Ratio 9.04 (M3P Rear Motor
Drive Unit - Plaid
- Front DU → 5D1 → 314kW / 482Nm / 350V / Ratio 7.56
- Rear DU → 5D2 → 2 x 309kW / 2 x 482Nm / 350V / Ratio 7.56
Diskussion zum Thema bitte hier:
