After driving the car home from work today, I noticed that the battery pumps were quiet when I parked. I quickly checked Scan My Tesla and surprisingly the pumps were at 23%. The only change I made was that I turned off range mode.
Then I performed a coolant purge until completion. Both battery coolant pumps and the power train pump were at 100% the entire time as expected. The radiator bypass (3 way valve) was also at 100%.
After the purge was complete, the pumps went back down to 23% each and I put everything back together. I was happy at this moment.
I took the car for a drive to the supercharger and then thats where the battery pumps went to 100/127%. I’m not sure if its because I turned on the AC or if something else is wrong. I have no idea
While I was supercharging, I did not see the batteryheater error as we discussed earlier in the thread.
At some point during supercharging, the battery coolant pumps both went from 100%/127% to 46% each. I decided to turn on the AC and then a few moments later they went back to 100%/127%.
I am still unsure if the AC has anything to do with this issue. I’m unsure.
I do notice that louver 5 is always stuck at 77.2. I’m not sure how to fix this or if it has anything to do with the battery coolant pumps.
I checked the 2 pin connector from the battery heater hose and it seemed to be normal. I did not unplug it to check the connection because I was performing the coolant purge. I will check again sometime this weekend.
The 3 and 4 way valves are coming on Monday. I plan on changing out the 4 way valve since I know that the 3 way valve is working properly.
I am so sad lol.
EDIT:
To add, I joined the scan my tesla discord and the developer confirmed that „SERIES/PARALLEL“ is most likely the 4 way valve.
Welche Alerts waren Activ und welche sind jetzt in Recent-Liste: vom Zeitpunkt der SuC-Session?
Gab es eine Meldung im IC, dass „die Leistung der Innenraumklimaanlage ist Reduziert um HV Systeme zu kühlen“ oder so ähnlich?
Wenn das Kühlsystem bei abgeschalteter Klimaanlage richtig funktioniert und erst bei Klima AN die Störung mit den Pumpen kommt, dann hängt das ja zusammen.
Eigentlich 2 getrennte Systeme, die aber im Chiller verbunden werden.
Jetzt ist da die Frage, ob es am 4-Wege-Ventil liegt, oder doch am Kältemittel.
Ich persönlich würde jetzt die Klimawartung machen, damit man weiß, dass da wirklich vorgeschriebene Menge des Kältemittel ist. Andere Möglichkeit das zu prüfen gibt es leider nicht.
Es schadet ja nicht und muss trotzdem irgendwann gemacht werden.
Warum also nicht jetzt?
Wann wurde das zuletzt gemacht?
Womöglich doch noch nie?
EDIT:
Thermaltest wäre jetzt von Vorteil.
Kannst Du vllt zu Tesla SeC oder Body Shop (ich mag SeC auch nicht )fahren und dort um die Durchführung des Thermaltest mit der ToolBox bitten?
Mehr als 15 Minuten dürfte man dafür nicht brauchen.
Dann das Ergebnis fotografieren oder ausdrucken lassen (wenn möglich) und hier posten.
PM_w041_dasMIA und THC_d0018_activeAero kannst du ignorieren. Diese Alerts sind mindestens bei meinem Model S immer wieder da seit Monaten und alles funktioniert.
und dann statt xy€ im SeC für Re-Kalibrierung Louvre lieber gleich Stoßstange runter und neue Shutter/ Louvre bezahlen.
nicht bei dem THC_d0018_activeAero Alert.
Es dauert nicht lange und weitere THC-Alerts bezüglich Shutter werden auftauchen. Wie bei allen anderen, die diese Fehlermeldung auch ignorierten und ignorieren.
Nach meinen Informationen können Toolbox Bestellungen aktuell nur mehr von Unternehmen durchgeführt werden. Das 1 Stunden Abo ist auch nicht mehr verfügbar.
Zu den auftauchenden Fehlern finde ich keine Infos bzw. nur Hinweise zum ActiveAero.
W0145_rfrgSuctPressRange und …PressLo hängen vermutlich mit der Klima zusammen. Diese läuft kurz an und bricht dann ab.
Dennoch lädt der Wagen am HPC noch normal was vermutlich a den -1C liegt und das zum kühlen ausreicht.
Hallo, ich habe glaube ich das gleiche Problem.
MCU1 P90DL Model S (2016 Facelift, AP1)
Fehlercodes: THC_d0005_pumpBat1, THC_w0052_sanityPumpBat1, THC_w0115_sanityBatHeater.Ich bestelle heute einen Thermal Controller und werde hier updaten, ob das das Problem löst.
Meines Wissens kann der Batterieheizer nicht schuld sein, da es ein HV-Bauteil ist – bei einem Defekt hätte man BMS-Fehler bezüglich externer Isolation bekommen („BMS external isolation faults“).
Bei mir ist der Batterieheizer vor etwa einem Jahr an einem Supercharger ausgefallen – das Auto war komplett tot und es kamen BMS-Fehler, keine THC-Fehler.Es wird also entweder an den Pumpen oder am Controller liegen.
Ich habe ein paar Beiträge gesehen, wo Leute sowohl die Pumpen als auch den Heizer getauscht haben und die Fehler trotzdem geblieben sind – deshalb gehe ich jetzt vom Controller aus. Die Teile sind richtig günstig zu bekommen, ca. 20 € inkl. Versand nach Ungarn. Das eigentliche Gerät kostet lächerliche 7 €. Sobald es da ist, baue ich es ein und gebe hier Bescheid.
Sorry, falls meine Erklärung schwer verständlich ist – ich musste einen Übersetzer benutzen, mein Deutsch ist schrecklich, ich spreche nur Englisch.
Hallo, interessante Entwicklung in meinem Fall. Ich habe Screenshots angehängt. Heute Morgen hat mein Auto die Batterie ganz normal geheizt (es standen 3 Balken neben der Batterie und nach dem Einsteigen hatte ich wieder etwas Rekuperation / Bremsenergierückgewinnung zur Verfügung). Die Außentemperatur war null Grad. Von den 3 Fehlercodes sind noch 2 übrig. Ich habe – im Gegensatz zu manchen anderen hier – nach dem Ausschalten des Autos keine Pumpengeräusche. Mein Controller ist noch nicht angekommen, sobald er da ist, werde ich ihn tauschen und dann berichten, ob die beiden verbleibenden Fehler dadurch verschwinden oder nicht. Momentan stehen die zwei Fehler im Service-Modus, das Fahrzeug läuft aber ansonsten wie erwartet. Die Batterie wird normal geheizt.
I wanted to place this link here from another forum where someone had the same issues as we did, but the reason why their battery pump kept running was because of a cut wire.
