Liste der Sprachkommandos
von rachid » 19. Jan 2017, 09:24
Interessanter Fund aus dem TMC!
Die Liste aller möglichen Sprachkommandos. Ich habe nur die deutschsprachigen unten aufgelistet:
Code: Alles auswählen
    "voice_command_list" : [
            "command_type" : "navigate",
            "description" : "nach navigieren",
            "command_regexp" : "^nach\\b(.*)\\bnavigieren$"
            "description" : "zur navigieren",
            "command_regexp" : "^zur\\b(.*)\\bnavigieren$"
            "description" : "zu navigieren",
            "command_regexp" : "^zu\\b(.*)\\bnavigieren$"
            "description" : "nach fahren",
            "command_regexp" : "^nach\\b(.*)\\bfahren$"
            "description" : "zur fahren",
            "command_regexp" : "^zur\\b(.*)\\bfahren$"
            "description" : "zu fahren",
            "command_regexp" : "^zu\\b(.*)\\bfahren$"
            "description" : "wo ist",
            "command_regexp" : "^wo ist\\b(.*)$"
            "description" : "navigiere nach",
            "command_regexp" : "^navigiere nach\\b(.*)\\b$"
            "description" : "navigiere zu",
            "command_regexp" : "^navigiere zu\\b(.*)\\b$"
            "command_type" : "call",
            "description" : "wählen",
            "command_regexp" : "^(.*)\\bwählen$"
            "description" : "anrufen",
            "command_regexp" : "^(.*)\\banrufen$"
            "description" : "wähle",
            "command_regexp" : "^wählen\\b(.*)$"
            "description" : "ruf an",
            "command_regexp" : "^ruf\\b(.*)\\ban$"
            "description" : "rufe an",
            "command_regexp" : "^rufe\\b(.*)\\ban$"
            "command_type" : "note",
            "description" : "note",
            "command_regexp" : "^note\\b(.*)$"
            "description" : "report",
            "command_regexp" : "^report\\b(.*)$"
            "description" : "bug note",
            "command_regexp" : "^bug note\\b(.*)$"
            "description" : "bug report",
            "command_regexp" : "^bug report\\b(.*)$"
            "command_type" : "play",
            "description" : "spielen",
            "command_regexp" : "^(.*)\\bspielen$"
            "description" : "hören",
            "command_regexp" : "^(.*)\\bhören$"
            "description" : "abspielen",
            "command_regexp" : "^(.*)\\babspielen$"
            "description" : "abhören",
            "command_regexp" : "^(.*)\\babhören$"
            "description" : "spiele",
            "command_regexp" : "^spiele\\b(.*)$"
            "description" : "spiel",
            "command_regexp" : "^spiel\\b(.*)$"
Quelle: https://teslamotorsclub.com/tmc/threads ... car.84626/
Seit 2019 M≡ Performance, Erweiterter Autopilot (eventuell FSD), Schwarz
2015-2019 Model S85, Pano, Autopilot, Doppellader, Deep Blue Metallic
Re: Liste der Sprachkommandos
von pollux » 19. Jan 2017, 10:55
Danke für die Liste.
Da ich bei Verwendung der deutschen Sprachbefehle immer schlechtere Ergebnisse erziele, verwende ich weiter die englischen. Falsch, den englischen. Denn eigentlich verwende ich nur "navigate".
"call" mach ich lieber und zuverlässiger mit Siri.
"play" braucht man nicht wenn man Radio hört und mit "note" weis ich nicht so richtig was anzufangen.
Ist nicht so dolle was man da mit Sprachbefehlen machen kann. Aber steht auf meiner Wunschliste so wie so sehr weit hinten.
S85D seit Mai 2015 (verkauft mit >200.oookm)
M3 LR seit Feb 2019
Bagger (Elektrolader Schäffer 24e) ab Jan 2020 :-)
von Andi-E » 19. Jan 2017, 13:54
Wenn man eine Telefonnummer googeln und anrufen möchte kann man navigate sagen, gefolgt von dem Namen einer Firma oder einer Privatperson mit Wohnort. Dann wird das Ziel auf der Karte angezeigt mit einem Anrufbutton den man nur noch drücken muss. Nix Neues aber vielleicht nicht jedem bewusst.
S85 Oktober 2014, Tech, Air, Sound, AP1, Aludach :), 22kW Doppellader
M3 LR dual motor
von ensor » 20. Jan 2017, 00:09
Funktionieren bei euch die Bug Report Befehle, wenn das Fahrzeug auf Deutsch gestellt ist? Klappt bei mir nicht. Im Display wird es zwar korrekt erkannt, das Model S weiß dann allerdings nicht was zu tun ist.
von TinyTiny » 20. Jan 2017, 03:18
Habe mal nur die dt. Befehle raus gefiltert, damit es übersichtlicher wird. Sowas habe ich schon immer gesucht.
Danke Dir rachid !
Viel Spass und Erfolg beim testen wo man was wie spricht.
"nach navigieren"
"zur navigieren"
"zu navigieren"
"nach fahren"
"zur fahren"
"zu fahren"
"wo ist"
"navigiere nach"
"navigiere zu"
"wählen"
"anrufen"
"wähle"
"ruf an"
"rufe an"
"note"
"report"
"bug note"
"bug report"
"spielen"
"hören"
"abspielen"
"abhören"
"spiele"
"spiel"
Fahrzeug: Tesla Model X
von Boris » 20. Jan 2017, 18:48
Wir hatten das schon hier gesammelt:
viewtopic.php?t=13572
Zusammenstellung auf Seite 1.
Model S: P90+, Multicoat Rot, ausgeliefert 06.03.2014 (07/2019 90er Akku erhalten)
Model 3: LR DualDrive, AP, Midnight, ausgeliefert 15.02.2019
1x Model 3 Reservierung vom 02.04.2016 in Reserve
von rachid » 21. Jan 2017, 00:09
Die hier oben sind aber direkt aus dem Tesla Quellcode.
von Integer » 21. Jan 2017, 17:06
@pollux Da ich bei Verwendung der deutschen Sprachbefehle immer schlechtere Ergebnisse erziele, verwende ich weiter die englischen.
Bei mir funktionieren die englischen Suchbegriffe leider nicht mehr. (Beispiel "Listen to ZZ Top" or " navigate to .. ") Hatte früher (mit 7.1 ) immer gut funktioniert und jetzt mit 8.0 versteht er nur noch Deutsch :cry:
Muss ich die Systemsprache auf English umstellen damit er die englischen Sprachbefehle versteht? oder geht Deutsch und English bei Euch mit Systemsprache Deutsch? mmm habe Schweiz eingestellt vielleicht muss ich Schweizerdeutsch sprechen.
Model S 85, 90'000Km, letzte pre Facelift Version März 2016
Bis jetzt keine Reparaturen,
TR=386, SW=2019.16.2
von Andi-E » 22. Jan 2017, 08:07
Probier mal navigate ohne "to" und play. Das sind bei mir die am besten funzen.
M3 LR dual motor
von pollux » 22. Jan 2017, 08:19
Bei mir ist alles auf Deutsch eingestellt.
Ich nutze auch nur Navigate und Play. Beides ohne Füllworte drumherum.
Das funktioniert dann recht gut.
M3 LR seit Feb 2019
Mitglieder in diesem Forum: sbob2000 und 3 Gäste
